Hi everyone,
Here are some close-up images where I wanted to capture some details in the materials.
Hope you like it
PS: I had to change the original images because I noticed some errors, here are the new ones
Love the plywood texturing. Particularly the wear around edges. Where did you get them?
Hi @RB_Design , thank you, the plywood texture is from this scene: https://www.turbosquid.com/3d-models/modern-interior-3d-model/975023
@Vlad_Moldovan That’s really amazingly well done - Was this done in Sketchup? If so did you have to make use of Transmutr or how did you bring the textures into the model?
nice shots !
Thank you @Valaskjalf , yes, everything was done in SketchUp, I also used Substance painter for one pot. I use transmutr and skimp to import models and uv’s but I also get great results with Thru Paint for the textures.
Thank you @Yuri.Ismalova
