This error message was displayed while trying to render:" device or resource busy: device or resource busy "
Would you be able to provide your scene please? The only way for us to fix this kind of issue is to get the scene in question..
Instructions on how to send the scene to us can be found in my signature.
Cheers,
Rowan
Won’t be able to upload the file considering that the file size is larger than 256 MB.
can I upload it using wetransfer instead of dropbox?
Thank you in advance.
You can use our drobox link, it will allow you to upload files up to 10GB. The benefit of this is that it is privately sent to us.
Alternatively if it is a problem you can use wetransfer and you can just drop me a PM with the link.
Cheers,
Rowan
We are a busy production studio and have been experiencing this same issue intermittently over the past week.
It’s starting to cause significant issues with our production timelines.
We have noticed in the scenes with these issues, when displacement is turned off the issue resolved. Would it be possible to please advise as soon as possible whether there is a solution for this?
Thanks,
We are aware of this, would you be able to provide us with a scene where you can reproduce this issue? Unfortunately we have not been able to reproduce the issue so far.
Instructions on how to send us a scene can be found in my signiture.
Thanks,
Rowan
Hello guys,
Did you find any solution to this problem? I only just installed the 6th version of Corona Renderer, previously did not have such problems
Yes, something is wrong with the 6th Corona. Got back to 5 (hotfix 2) and working fine. I can send you the scene if needed.
If you can send a scene it would be helpful, instructions on how to send it to us can be found in my signature.
Thanks,
Rowan
Same problem here suddenly occurs now, when rendering with IR or production … first time I see that, with this scene or with Corona ! using 3dsmax 2021.3 & Corona v6 hf1.
Uploaded the scene on your uploader, scene name: NCaplat_Koenig_max2021.zip / support ticket #199639.
Thanks a lot.
Regards.
Thanks for reporting this, we have already fixed this issue in the v7 daily builds.
Cheers,
Rowan
(Internal ID=591961402)
Great news ! thanks ![]()
