Diferent image in DR render
Hi, in some scenes I have this doble image error when I render wuth distributed render.
All slave makes an Y-offset in the image that they send to the master.
Corona 1.5 fix2 version
Can you help me please?
Thank you
Probably something else, but did you make sure you render through a camera, not a perspective view?
No prespective view, is an VrayPhysicalcamera view.
I test with Standard max camera and obtain the same result.
Did you have a chance to try the new DR in 1.6 daily builds? Is the issue still present?
Hi, do you to use the stripe render via backburner or the DR server from corona?
If you could upload your scene somewhere and send it via PM I can give it a try on our environment.
