difference in reflection
I ran a test using both CPU and GPU, although the GPU rendered quicker, the results were not as good. It appears more flat and the reflections were not as crisp.
Any ideas on how to improve so it is more crisp?
Are those VRayBlendMtl materials?
Its a shellac material with Vray materials used for base and shellac. When I said CPU I meant normal Vray, its a different reflection when using RT GPU and CPU.
The GPU version renders just the base material, that’s why it looks different. We are working to support complex layered materials on the GPU.
Ah cool thanks :slight_smile:
