Does anyone know why i am getting different results from the latest release, compared to older versions of Corona:.
Look below:
The top image is the original correct image.
The bottom is the new “too dark” image from V1
Your comments made me review the scene and i think i found the problem.
At my home computer (newest render) the scene would report a missing file:
“C:\Program Files\Autodesk\Mudbox 2015\textures\Lightprobes\horizon.exr”
I just ignored that, because I never added this file to the render (I think) and I am guessing that is the problem.
I will confirm when I get home later today.
If you are using a bitmap as background (or enviro or light or whatever), check what is the gamma setting in the window where you are loading the file. I mean this place:
Some more info here.
I have been rendering this image from two computers, both had A7.2
Without changing anything in the scene, only upgrading to V1.0 this happened.
I am using a normal camera…
I have not installed v-ray
I am not using an image input for light, bg or anything (gamma).
For BG I am just using the RGB color 0,3,7 (very dark blue) I realize that this dark blue is amplified (or something) in the correct/original image, but not sure how???
I’m surprised A7 did not render it like 1.0 . The new one in 1.0 is behaving correctly, cause gamma correction is off, the older one is technically “wrong”. What happens if you activate gamma correction in 1.0 ?
I can enable it, but not sure what the value should be… Have played around with it before i posted first.
It gets almost right. BG color is much more “correct” but sails that are self illuminated a bit are way off… too saturated.
You had been using 7.2 without gamma correction but Corona assumes and requires a gamma 2.2 workflow for correct output. For some reason 7.2 already saved in gamma 2.2 that’s why your old render looked brighter than in 1.0
The problem is: your textures were not properly gamma corrected back than, they were loaded in a way that made them look brighter than they are now. With gamma correction enabled, they get the proper correction applied and look the way the are supposed to look (like the textures you have on your hdd). So, now it’s correct, back then it was incorrect.
To achieve the same look now you would have to load each texture with an gamma override of 1.0 in the file open dialog (which would again be technically false but it would look the same)
