I made render for few boxes with simple glass shader. If caustics are off then shadows are not so intensive (refraction color is 250,250,250 ).
If turn on caustic - shadow is going to be black (refraction color is the same - 250,250,250).
Is this bug or a physical correct feature?
This is intended bias to prevent fireflies. You can set the render engine to PT+PT with MSI 0 to get the unbiased result, but it would created fireflies. You can also set Renderer in main tab to Bidir/VCM to get unbiased result, although fakes are not supported in that mode
