I’m having problems with Vray Fur. Different buckets produce different results. Please take a look at the attached image. This is rendered on a single PC, no DR or Backburner is used. Vray version is 3.20 on Max 2016.
Not sure what’s going on right away; can you get me a scene for this to vlado@chaosgroup.com (you can probably just remove everything bug the grass).
I just emailed you the scene. Hopefully we can track this down. ![]()
can you send us the original scene, because we cannot reproduce the problem with the current one.
P. Getov
Ok, I will send the completely untouched original scene shortly. The one I sent earlier had the unnecessary objects removed.
I managed to reproduce the problem with the original scene.
We are looking forward to fix it.
Great, thanks for the quick reaction, Peter. ![]()
the bug is fixed and the changes will apply in the next patch.
If you have access to the nightlies you can try it with tomorrow’s new build.
If you don’t have access to the nightlies and you need the changes sooner, talk to Vlado.
P. Getov
Thanks, Peter!
