Hello
I’m getting a different result between the IR and final render.
Material is applied using cubic projection and via a selection tag.
Full-speed non-debug version Build timestamp: Aug 3 2021 16:40:22 Version: 7.0 Cinema version: R21.207 Cinema 4D (mutli-license) Plugin status: Plugin successfully loaded
would it be possible to send us this scene to investigate? You can use the private uploader or dropbox.
Thanks, Jan
Private Uploader:
Thanks Bengamin and Jan
I realised what the issue was when stripping down the scene to send to you - I had the geometry with the tiles duplicated. If the scene might still be of use I’m happy to send it but this one might need to go down as operator failure on my part.
you got me worried a little there. Glad this was resolved.
