Hi all,
doing a test at 1500 pixels (full image) and 3000 pixels, I get two objective results. You can find them attached.
In the 3000-pixel image the bushes appear to have correct saturation, while in the smaller image they seem much less saturated and darker.
With interactive render I encounter the same problem, to get the correct saturation I have to use the 2d Pan Zoom mode and zoom in on the bushes.
I never had this problem in the past, if I rendered a 1k or 5k image the result was identical.
I am using Max 2022 and Corona 9 Hotfix 2.
The leaf material has translucency with Fraction at 0.5 and a leaf texture for Translucency color, no volume or refraction enabled.
Thanks in advance for any help.
