different render between RTcpu and RT gpu
Hi all, I made a small test,but the render between Rtcpu and RTgpu are different.
can you help me?
p.s.
in the file there are vray sun and vray cam, all material are vray standard material.
Yes, the CPU is wrong :slight_smile:
I’m uploading an updated build now.
Vlado, does this mean that the RT/GPU Beta has within it an updated RT/CPU build? …And if so should folks start using it for RT/CPU even if they aren’t using RT/GPU quite yet?
Thanks,
-Alan
Yes, the CPU/GPU switch is just an option in the V-Ray RT render settings. You can certainly use it for CPU rendering even if you don’t have suitable GPUs.
Gotcha - Thanks,
-Alan
sorry but the the GPU it’s wrong.
2°test whit evermotion file.
can you help me?
Thanks,
radiosity
:face_with_spiral_eyes::face_with_spiral_eyes:
Can you get me the file for this to vlado@chaosgroup.com?
Looks to me like u are using blend materials… and GPU simply dont know what to do… I had something similar in my scenes…
I’ll be adding an option for the next build to print out warnings for elements in the scene that are not supported…
ok.I send to you a file now.
thanks
