different render times same machine specs build 09-06-15
Hello guys, from daily build 09-01-15 till today i have some machines that are rendering like super slow excesive times vs some machines that render time as always, its a video and the average time is 50 min to an hour per frame but some machines hang and give 258 hours with no result, also displacement is turned off and the uhd calculation is pre saved, machine specs are, i7 32 gigas of ram all of them, i have to different machines with intel xeon dual cpu with 64 gigs of ram with no problem, its a heavy scene, all the cars are proxy also trees and furnitures, forest for the trees, corona sun wirh corona sky
can you try the solution from this thread? Parsing the scene and network performance - Corona for 3ds Max :: Issues - Chaos Forum
Can you also screenshot the “stats” panel on both master and problematic slaves?
Hi, yes i will make some test with new build tomorrow but i can asure you there is no hair fur on the scene,not standard, not vray.
Should display an error message now if it’s FTH.
OP, what is the status of this?
If no response, will be moved to resolved.
