Different renderoutput using a Texture on VrayLight
Hi!
I’d like to know if this is a common issue or if I’m making some mistake:
I find really useful to use the RT-CPU for Still Life rendering, 'cause there aren’t few geometries and the feedback from RT is fast.
To make more realistic the final render I use a common technique: I create a planar VrayLight and I apply an hdr texture on it similar to these:
http://www.ossosso.com/public/scambio/test01.jpg
http://www.ossosso.com/public/scambio/test02.jpg
To be more precise the Texture is done in this way:
-VrayCompTex
-SourceA : the .exr file (Bitmap Map)
-SourceB : VrayColor Map (to change light color)
-Operator: Multiply A*B
…and I drag the VrayCompTex on the “Use Texture” of the planar VrayLight.
The Final Standard Vray render is good, no problem, but if I launch the RT-Cpu version, it is a lot darker then the Standard one.
I find out that it happens when I use the VrayCompTex on the planar VrayLight, because if I uncheck it both standard and rt-cpu are the same.
I don’t want to renounce to the .exr texture 'cause it gives more realism, but also I don’t wanto to renounce to the RT 'cause it speed up the workflow.
How can I conciliate them?
Thank you very much.
