Different sim result by using Standalone preview
Hi i’m new here,
recently i saw in the what’s new in phoenixfd 5
i just test the standalone preview , the speed is owesome! but i face one problem is the result was totally different between in the viewport and standalone preview sim
here is the comparison
Start sim in the viewport and standalone sim
My goal is need to follow my viewport sim setting, please give me some advise thanks!
Ah, this is because this preset uses animated Source discharge. Animated options are still not supported by the Standalone Simulator I’m afraid. I hope this will be coming to the nightlies soon…
Hey, just an update - I just got support for moving obstacles and moving simulators working in the standalone simulator. It will be in Sunday’s nightlies of Phoenix for 3ds Max.
After this, I will add support for animated Simulator options, and then the animated Source options will be coming.
So I hope by the end of next week the Explosion toolbar presets would looks the same between 3ds Max and the Standalone Simulator… :slight_smile:
Another update - in tomorrow’s nightlies for 3ds Max and Maya you will be able to animate the options of the Simulators. Now starting to look at animating the Source options and with this, you will be able to replicate the toolbar explosion presets in the standalone simulator… :slight_smile:
Will ping you again when this is implemented as well.
Alrighty, and finally, in tomorrow’s Phoenix nightly builds, animating the Source parameters would work in the standalone simulator and the Explosion and Gasoline Explosion presets will be doable in the standalone simulator :slight_smile:
Cheers!
