Different sized cascading grids - what am I missing
Hey there,
I am having trouble getting the look right when I change the size of my grids. When I do a sim like this
the grids are the same size and the join is seamless.
What I want to do is have a third and fourth grid here to continue the water flow down the river. I flatten the grid which obviously changes the cell size, and then I painfully tweak the cell size so the grids match but you can see where the flow from the second to third grid is.
What do I need to do for cascading grids to keep the resolution the same but the fluid grids are different XYZ sizes.
Thanks heaps.
Hey,
If you keep the cell size between the simulators equal you should be getting the same resolution. Why do you think this is painful for tweaking?
Cheers!
