I am having the problem that the Dim fall off has no effect no matter if it is set to 0 or 1.
Before it would fade over to where the reflections would be cut off but now it is cutting it off always harshly.
Hi thx for the reply. I found my original post was missleading, as I only looked at the reflection pass.
In the RGB color seems the falloff works but it doesn’t work for the passes.
This problem only happens when Consistent Lighting Elements is ON (so the default setting).
If you can’t reproduce this I can send you a scene ![]()
I see, it does indeed look like a bug: it’s impossible to obtain the original RGB through comping (the BackToBeauty RE setup also fails.).
Logged as VMAX-10449.
Thanks for the report!
Alright good to know, thx
It seems that it has not been fixed even in V-Ray 6.
