Direct visibility does not update in VFB if change material or do any setting. Have to stop start every time.
Using Corona 6.
Thanks.
Using Corona 6.
Thanks.
Hi Imran,
Are you referring to “visible directly” in the light options? Sorry for being confused ![]()
Corona Render setting, in Scene Environment.
Works fine on W10, C4D 23, Corona 7 daily 2
I think I can see what the issue is. If you add something into “Direct visibility override”, IR VFB gets updated, but if you change it by putting something else inside, VFB does not get updated. I will pass this issue to the developers.
In the meantime, you don’t have to “stop start” every time, you can turn off visiblity override and turn it back on (double click on the checkbox) and it will update.
Thanks for reporting,
Jan
