Hi Dave, I hope you’re able to do your job with Vantage.
I have news directly from NVIDIA, they have a fix for the SLI issue, which is now being tested, the fix is a tricky one(“in the deep parts of the driver”) and they need to be sure that another applications are not affected negatively, as much as possible.
Currently the fix is scheduled to be released, with the corresponding driver, in the end of September.
FYI I just encountered this same error for the first time yesterday. Had Max and Vantage open. Lots of Forestpack geometry and Railclone items.
Vantage has been rendering fine - I was batch rendering HQ cameras at 4032x1960, then going back to max and turning various layers on and off (Forestpack items), then re-rendering when it happened.
Locked me out of my system for a little while.
Wasn’t even maxing out Vantage memory.
Studio Driver 522.30 (10/18/2022)
No SLI.
Only one card (3080 RTX) being used.
I think you mean the same dialog popped up, but this can happen for a number of reasons. The original poster’s error was supposedly caused by an nvlink driver bug.
You probably ran out of GPU memory, this is what usually causes such crashes. The memory status indicator can update only after the allocation succeeds, so it might show a “low” value even if your memory is insufficient. Also, it only shows what Vantage uses and it sounds like Max could be using a significant amount in your scenario.
Do you have the “Safe GPU allocations” option turned on (it’s the default)? Have you noticed how much of the CPU RAM is free? (significant amounts of CPU memory may be needed while uploading DirectX resources to the GPU - this could also cause a similar crash)
Will try to pay closer attention if it happens again.
Safe GPU Allocations is on.
Is there a way to split Max/ with one GPU and only use the other GPU for Vantage? I know how to select a specific GPU in Vantage (the card with more memory), but wondering if there’s a way to allocate Max strictly to another GPU/card in this particular situation.
I recognize there’s a VRay GPU Setup dialogue, but my impression is that this is only for rendering and would have no impact. Maybe I’m incorrect.
