It depends.
Dirt can be put over diffuse in a mix texture, other people use An AO map as mask, others use multimaterials.
And scratches same as above but its dependent on size of scratches, heavy ones goes better modelled, medium ones use displacement small ones bump or a simple texture… who knows.
There is a post around when some poeple has put some numbers on it. (Use the search)
Check this blog. Its full of resources.
http://bertrand-benoit.com/blog/2012/04/15/materialism-1/
This link in particular describes some info on materials. Its a good start.
And the promo.
check this blog also, specially the makinf of section.
Tons of good stuff there.
http://www.ronenbekerman.com/architectural-visualization-tutorials/
Black Sun, I think you should be more specific. What do you mean by “dirt”? To what kind of material do you want to add this dirt (clay, glass, metal)? Do you want this dirt to affect reflectivity, glossiness, bump, or just diffuse colour? Do you want it to be procedural or a bitmap?
Almost forgot about these fine work here on the forum.
https://forum.corona-renderer.com/index.php/topic,4031.15.html
They use dirt in composite map.
You are probably referring to ambient occlusion. In Corona you can find it as a CoronaAO map that you can plug wherever you want.
