It’s obviously working because when I add it as an extra texture-dirt map then I get a thin line around the bottom of objects but that’s all. I’ve attached some renders to show. I played with the sliders and just get a darker line but no shadowy corners. Also played with exposure but get the same, material override on or off - get the same
Yeah I added so I have it as an extra layer for post production but if just turn on AO I get the same effect. I don’t really want to have to add AO to every layer I would rather it just worked as it should. I’ve followed the tutorials I have found and simple don’t get the same results, just a strong black line.
If you work in mm than you get 10mm dirt effects only at the moment. Also you use fallof 0 and maybe this cause a focused effect. So, the AO could be looking like a black line. I think, it’s a question of adjustment only. For example I would try radius 100 and falloff 1.
