Dirt map?
I’ve been playing with corona for the past couple of months. I’m sure that it’s going to be one of the best render engines in it’s class. I have some topics that i’m not very happy with…but the most important is that every cristal clear render done in corona is soooo clean…too clean :). Don’t get me wrong…it’s a good thing…but some times i find myself trying to use a vray dirt map for occlusions and ruffing up the render. It’s something that can be done in post production sometimes…but it would be a very very VERY usefull thing to have in the material options. Is there a way to obtain this effect allready and i’m wasting my keyboard here? :smiley:
Thx corona forum…
AO is very usefull as an plane intersection solution (wall and ceeling for exemple) but what about situations like this one? ( floor and kitchen island touching area ) I feel like ao pass is just not enough :smiley:
Thx
http://www.3dmacher.com/daten/forum/3.jpg
I’m 90% sure in the picture you showed there is no AO/dirt map/whatever you call it used. The effect of corners and thin gaps being darker than the surrounding environment is natural and should be provided by GI only. Using AO in such situations is adding fake additional darkness to those areas.
To get darker corners you need to decrease albedos of the materials and compensate the overall brightness with exposure. One typical error people keep doing again and again is setting albedos too high to compensate for not using linear workflow. This will not only increase significantly your render time, but also wash away all the little shadows in corners. AO should be only used to create custom shaders simulating dirt/wear&tear look, not to set up lighting of the scene in any way.
Thank you, very usefull info.
Keymaster, have you considered getting in touch with Matthias Senz from enRichPro (making RichDirt) - I have already been talking to him about Corona and he seems interested in porting RichDirt to Corona to. if you are interested I can give you his contact data.
I guess it could be done with a shading API, I will try to release it sometimes before A6. Or I can find other solution if he contacts me.
Any news about Richdirt support ? Its one of the best texturing/post related plugins ever, it is a game changer for exterior visualisations and can be quite useful for some interiors too and would be awesome if corona could support it. Of course it would be even better if it could be implemented using like you wrote “other solution” - cause, for one, I don’t want to buy another licence if Matthias decides to release special version for Corona only and for two, I think conversion of some old v-ray based assets\scenes would be much easier this way. Yet still I’ll will buy it again if there is no other method than to rewrite it specifically for Corona.
P.s I don’t know, maybe I should post that as a separate feature request ?
RichDirt support is required for Corona.. its the best solution for dirt.. btw AO is not dirt.. if you check out RichDirt you will know the difference. RichDirt rock.. Corona need it :smiley: Waiting for you guys to make it happen :smiley: Thanks :smiley:
RichDirt is for sure a VERY cool tool. I have used it with MR for 1-2 years and it can really give things a push towards realism.
I am frequently in contact with Matthias from EnrichPro - the producer of RichDirt. I have been trying to convince him that Corona should be his next move. I caught him probably at a very bad time, as it was at the time Vray 3 was about to release - and he was struggling to get an update ready for this.
Matthias is a little worried about if he will earn enough porting Richdirt to Corona. There are many render engines out there, and its always a little lottery to pick the next to port to, - and see if the programming effort gets payed off. I really try to convince him that Corona is a sure and safe pick for next porting - especially for the archviz world - which, I guess, may be seen as his main customers.
I don’t know how much work there is in porting RichDirt to Corona - but I would for sure recommend Ondra to contact Matthias for a chat about a common effort in getting RichDirt working with Corona. I am sure a push from other users of Corona would make the decision easier. So please go in at http://www.enrichpro.com/en/richdirt/contact.html and give Matthias a push towards the light :o)
Any news about RichDirt support for Corona ?
AO can´t replicate the same as VrayDirty or RichDirt. If it can, please, give a clue about it ! :smiley: Vray Dirty has adjusts like Spreading in Axis with separated parameters... And RichDirt looks AWESOME !
Bueller… Bueller. :smiley:
I’ll just bump this one because it would be an invaluable time saver :smiley:
No news, Matthias from enRich Pro is still reluctant porting to “unknown” renders. He say he can’t afford it.
I think he need to be pushed from as many as possible from the Corona community to see the light.
A chat with Keymaster might help to. As I have said before, I have no idea how much work there is in porting RichDirt to Corona, and maybe a chat between Matthias and Keymaster would enlighten this, and could inspire Matthias to start porting. I have tried the best I could to animate him to do it, but it seems like I didn’t succeed.
Hi all,
Sorry for digging up the thread, I thought it looked like the right place to ask my question…
I was wondering, is there a way to do a RichDirt-like mapping with Corona now (v9)?
I’d use it mainly for applying the stains only on the upper parts of concrete or metallic structures and, of course, decals would make this too tedious a work (unless I’m missing something).
If not, could this be added to the AO or curvature map as an additional (direction or XYZ degree + strenght) parameter?
Thanks!
Corona AO has directional offset feature since forever. Give it a try, it might not be as sophisticated as dedicated tool like RichDirt, but nonetheless you can quite easily achieve convincing weathering effect with Corona AO.
Yup, we have:
AO map - Corona for 3ds Max
Curvature map - Corona for 3ds Max
Triplanar map (can be used to apply an effect only to the top/side of an object) - Corona for 3ds Max
Thanks for the quick replies! Will try all the suggestions asap.
