Dirty Meshes
For those of you that don’t get to clean polys enough at work, now you can do it for fun!
http://home.cwru.edu/~jnt5/Planarity/
:stuck_out_tongue:
ghhha…must…stop…It awakens the autist deep inside of me.
This game should be handed to all FormZ modelers.
level4.. thanks! ~670pts… sorry don’t have enough time for this sandbox..i have still have viz4
lol…great…perfect…actually…that´s work not fun…but then again…it…is…fun…must…stop…no…more…cleaniiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiing…wahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
:roll:
Greetings,
Thorsten
:shock:
i cant get by 6th level
Level 9 and still plugging along :slight_smile:
score = 49097
this is awesome.
to instinct: LOL :smile:
heheh just got thru level 10 in 6mins :slight_smile:
quiting at level ten..I fear if I continue there will be no return…
hmmm, maybe a good test for new applicants :wink:
hehehe it is mighty addictive.
Well i spent about 5mins on level 11 and gave up. Got to much work to do, and playing this game is just posponing it. (spelling)
theres definitely a technique that will get you through it quicker. If you follow a few rules, each level really isn’t that much harder then the last.
well. dont leave us hanging
lol…
An edit on Percy’s post
In your best YODA voice:
A technique that will get you through it quicker, there definitely is . much harder then the last, each level really isn’t, If follow a few rules you will. :lol:
well heres a couple things Ive found. They might seem obvious I dont know. When you click on a node, you see the ones that are connected to it in red. Try to keep red nodes as close to each other as possible. Also some nodes are attached to less nodes then others. Try and get those on the outside and the nodes attached to alot of others more to the inside.
Its not essential you do this 100% but Ive found when Im done with one, it usually follows this somewhat anyways. Also at the beginning, I found I did alot of node pushing while not realy taking a second to look at how the node fits into the bigger picture.
Anyways, no eathshattering secrets, but hey if it helps…
whats your highest level so far percy?
ive gotten to level 10 twice before I had to quit. I might try it this weekend when Im not at work…
Yeah i just got to level11, and took about 25mins to finish it. Most other levels where under 2 mins except the 9 and 10. Had to quit at 12 as well.
Have you seen the high scores :shock:
