Disable Enscape light reflections in material
Is there a way to have the Enscape lights not reflect in the material? Like, a toggle to turn off relfection of light, but keep the diffuse and specular contribution?
The only way I have found is to put something in the way of the reflection. (I think you can use a surface that is only transparent on one side so you can see through if from the ‘camera’ side, but it won’t be too pretty in ‘walk-through’ mode and you need to make sure it does not block the light or be in the reflection it’s self.)
@vjaramillo_cg , this is not yet directly possible (through our settings for example), but maybe the workaround @Gadget_1 proposed would already work out for you? If you wish, I’ll happily upvote the existing feature request, just let me know if there is anything further you wanna add to it. :wink:
Coo…I’ll post on new feature request section.
