Heya
Using RT is a pain in the *&&… Most of my scenes have a lot of displacement and TS/MS applied to them. Any chance to have a tick box to disable TS/MS so scenes would transfer faster and work better on RT please?
Heya
Hm there is already a displacement check-box but it only affects render-time displacement done through the VRayDisplacementMod modifier or through a material. If you don’t want TurboSmooth or MeshSmooth modifiers to be taken into account then just turn them off for the viewport (the RT engine always takes a mesh as it appears in the viewport).
Aaa ok then, I thought vray use the render settings. In that case I’m set to go and time to optymize scenes for usable RT use hehe.
Thanks, bye.
On Scriptspot, if I remember correctly, there is a script to disable TS and MS with one click.
Yup I got it, I did use it a lot lately but I think there is no tick to just disable - but rather change all ts/ms options at once. Gotta open it again and just re-edit the script I guess to do what I want to do - good tip thanks mate!
