Disable Max Gamma Correction and use VRay's LWF button?
I’m still on 2009. Should I do anything differently? Is bitmap output (which is always 1.0) the output in exr too?
If I use Don’t affect colours I can’t use Reinhard values either. What should I change if I have that off?
Yes, there are a few differences.
Is bitmap output (which is always 1.0) the output in exr too?For OpenEXR output, you will need to keep the Output gamma to 1.0. 3ds Max 2014 is smart enough to know that OpenEXR files should always be saved with gamma 1.0, but for 3ds Max 2009 you will need to specify that explicitly.
If I use Don’t affect colours I can’t use Reinhard values either. What should I change if I have that off?This will be possible with the next service pack, where the “Don’t affect colors” option is changed so that it only skips the gamma, but can apply the other color corrections.
Thanks Vlado, will try with my next scene
So what are my differences? Especially if I have Don’t affect colours turned off.
Everything else is like it was said here.
Vlado, does your suggested workflow hold for RTT baking as well?
Corrected.
Glad they got something right though.
I imagine it would be the same for RTT as well.
Hi All,
Thanks for digging deep into this topic that is so confusing and so important at the same time.
I accept the theory that the inputs needs to be linearized (textures and rgb values) to have a correct render in linear space.
I understand as well that the file itself (32 bit exr/hdr/ etc etc) is stored in linear and is only DISPLAYED with an sRGB curve on top whitin the vray framebuffer and later in a compositing package as nuke, fusion, ae using a lookup table.
Again, the reason for such a workflow is that we don’t want to break the math rules behind the image and have all working properly in post.
I am ready as well to take for granted that we get a flat image that needs to be color corrected to give its best and stick with the rule of cgi: what looks good is good!
What I don’t get is why my images looks much more photorealistic using the lwf button than the workflow suggested by danb4026 and confirmed by Vlado.
I am very well used to danb4026 workflow. It is the workflow I use since 4/5 years and always thought that there is something wrong with the math behind it.
I have largely used it and experimented with it and I always end up with an image too flat. Too much.
It is pretty much impossible to control a reflection, all the important values are concentrated at the early numbers.
Example: if you need to make a black material slightly reflective you’ll give it a diffuse value of 1 or 2 out of 255.
After that it starts to become a dark grey. As well the reflection value has to be selected in the range of the first 10 values, after that you get something much more close to a mirror material than a black reflective mat.
What about the remaining 240 values?
This as well happens with the procedural maps, fallofs gradients. the fog color for example is another value that is hard to control.
And why should I choose a a white 180 to for a white wall? 180 seems grey to me, not white?
In my opinion the above workflow corrects only the bitmap input. It takes the texture and make it darker to display correctly under an sRGB LUT.
What vray doesn’t do is counteracting the colour values. The colour remains the same, just get brightened up with the above workflow.
That’s why most of the values are lifted on the bright side.
Try to create a gradient in photoshop, apply an SRGB curve on top and you’ll see that most of the dark values are gone.
The gradient is much more versed towards the bright side. someone will probably reply that this is because psp works in srgb space so it’s color picker is not linear.
The fact is that with the above workflow, if we want to reproduce a color, we have to pass it under a vraycolor node or just create a texture of it in psp and load it as a jpg.
I agree that photoshop is srgb so its color picker is already color corrected. For that reason I think that our rgb values has to be darkened to get a properly displayed in vray but this doesn’t happen.
The reason why that doesn’t happen in my opinion is because the Gamma & Lut panel in Max is built around the embedded rendering engine: mental ray.
there is adifference between mray and vray color values: vray select a color as an RGB value, mental ray select a color in floating point.
That makes me think that Max is clever enough to correct a floating point value but stupid enough not to correct an RGB value.
When you apply the gamma correction in max the material editor gets brighter.
Are we sure that this happens just because the light falloff is changing? to me it looks like that in vray the colors get brightened up. Is this correct?
And then what is the story with the greyscale maps? gamma 1 or 2.2?
and what happens to the procedural textures are they properly interpreted or they get broken from a wrong curve?
Again, loading textures and maps with a correction node is a little unpractical.
I usually work on huge scenes and the idea to keep the workflow consistent in a studio where we have often 10 freelancers is impossible.
Someone will break it so we need a magic button.
The magic LWF button as everyone always repeat is broken. It is wrong but it does the job. I know it doesn’t correct properly the fastsss2 maps, the vraylightmaterial and something else. But overall it looks good. Much more believable lighting distribution, much faster to implement, much more photorealistic. There are few maya tutorial out there that uses it. The same Rob Nederhost, Chaosgroup in the Maya helicopter tutorial (can’t remember the name of the author), Peter Guthrie on few occasions, and a great Max based company in Shoreditch I had the pleasure to freelance for in past. What I’m saying it is that a lot of top guns implements it. I agree it doesn’t correct everything and it works on the entire shader not on the single maps, but the render looks so much more correct and better that makes me think that this is correct. If it’s not please fix it and give us a definitive working magic button.
Regards,
Giacomo.
good thread, thanks all for discussing this stuff…those settings could be welcomed on the spot3d help pages, no?
Just to add some more to the list of things I think are not working properly following the workflow suggested by danb4026.
The vraysky and the kelvin colors. Vraysun & sky to my eyes works better with the LWF button, maybe because the colour gets corrected…
Kelvin: try to choose the same kelvin value on a vrayies and on a photometric light. You’ll end up with 2 different colors? why? Is this because of RGB vs Floating?
BTW I just want to highlight the fact that I have partecipated to few threads about LWF in the last few months and ironically the same people from Chaosgroup keeps on contradicting themselves on the correct linear workflow.
- Vlado in this thread confirming the workflow posted by danb4026
- Svetlozar Draganov suggest to use the LWF button on this thread http://www.chaosgroup.com/forums/vbulletin/showthread.php?68284-Cleanup-noise-in-Elements-Reflection-and-Shadow-Also-LOOONG-render-times&p=550494#post550494
- The same Svetlozar Draganov suggest a different approach again: http://www.chaosgroup.com/forums/vbulletin/showthread.php?70648-LWF-button-debug-list&p=565676#post565676
So, guys, what are we doing here? It looks like you are a little bit confused about it…
I would suggest AGAIN that you publish a proper correct linear workflow on spot3D, so we can save you a lot of headache.
I have the feeling that the right one is the last one, just manually color correct the gamma of the maps and color input.
Again, after 5 years, can we have a magic button that does it for us? We can’t color correct every single thing everytime…
The worst thing is that most of the places I freelance for in London uses as standard a workflow that is not correct, and please don’t try to tell them they’re doing it wrong…
… just to add some more confusion. Can you confirm that correcting the entire shader is wrong? I have seen few tutorials about Arnold and they seems to color correct everything: maps, shaders and lights… mmm…
Regards,
Giacomo.
The funny thing about this thread, is even tho some one is using the wrong approach in the right hand they can produced stunning results… :slight_smile:
Hey mcnamex,
I agree with you 100%.
My conversation is strictly nerdy and technical. In the right hands this software shines.
I just would like to nail the concept properly.
I don’t look at myself as a top artist and I’m not trying to blame the LWF if my renders aren’t top quality.
Regards,
Giacomo.
Hehe, I know which setups are correct (there is more than one possible correct set up) and I have explained them multiple times; I have also explained which is the preferred setup. Other people may have their own opinions and that is their right, of course…
Hi Vlado,
Thanks for your post and thanks because you’ve already explained me once what is your opinion on the LWF.
The fact that doesn’t convince me is that you suggest a “preferred” setup.
I think that gamma is a math operation applied to the images/color etc…
There’s shouldn’t be opinion and point of view about it. It’s not subjective. Either it is right or wrong.
All the 3 setups I have mentioned above produces a different render if you start to add reflections etc etc…
This means to me that there’s a single working LWF and other 2 that gets close or implement it in a different way.
If the workflow that you suggest is to manually correct maps and colors I keep on thinking that it would be sooooo great if you give us a button that does it for us.
I’m sure it won’t take too much to write a script or to correct what’s wrong with the LWF button we already have.
I am used to scenes with more than 10 milions polygons and more than 10 people working on it, I am not able to check that everybody has properly colorcorrected the material.
Again, no offence, but assume that I am a new user: why should I go through 30 threads on the forum trying to understand what is the latest opinion instead having it clearly written in the manual of the software.
If there are more than one correct workflow why don’t just choose one (the most correct or the easiest) and promote it on your website instead of leaving it for who is ready to read 10 pages of threads. You have to admit that this is a hot topic on the forum and I am sure that Chaosgroup will only benefit from putting it into spot3d.
Kind Regards,
Giacomo.
Change the output gamma in max then.
Change it in photoshop then, if you’re rendering to full float then the saved gamma being wrong doesn’t change the image. It only matters how vray sees the gamma.
Again I watched few other’s rendering engines implementation of the LWF and they confirm to correct both the textures and colors.
What I can’t understand is how the procedural maps, 3d maps and falloffs has to be implemented.
Assuming that we use the LWF from the gamma & lut panel: everything at 2.2 + gamma 2.2 on the color mapping map.
(btw I am pretty sure this is not a correct implementation of the LWF)
For example the fresnel button on the vraymaterial: is it corrected or should it be counteracted?
And eventually how can I do it? Probably I have to disable it, then use a gradient map set to fresnel and on top of that use a colocorrect node set at .4545
Again a gradient map or a noise map: is it fine as it is or should be corrected?
That’s seriously screwing my mind, I will really appreciate if someone could help solving the doubt.
Apologies but my post was not meant to provoke you for asking, the same thought cross my mind to the inconsistencies with LWF Approach from Chaos.
Where do we change Bitmap Input and Bitmap Output in max 2014?
I can’t find the parameters under Gamma&LUT tab. Are they set to 2.2 by default now?
This is the best approach; for the next service pack, the Reinhard mapping works in that scenario.
