Disable "Warning: No files saved" for render sequences with VRay Frame Buffer Render output
when I use the V-Ray Frame Buffer Render Output, 3ds Max asks each time to set up the render output in the common tab for sequence renderings.
So, 3ds Max forces me to set up a Max Render Output without having this warning message. Is there a way to disable this message? I does not make any sense to have two Render Outputs.
Thanks for your help.
The following warning is 3ds max related. We have sent a request to Autodesk, if it will be possible to disable the warning when VFB output is used. We will notify you, when we have any news.
Thanks for your reply. So far, I guess there are no possibilities to switch off this message. I keep my workaround to set the Max’s Render Output to avoid this message.
