is there way to make one object not reflect in another object? or not show in the reflection of another object, however way is easier to understand, just in that object as does in vray trace reflection options, thanks
No, that will do it for all objects, i need it for specific ones
have u tried the rayswitcher already?
i guess this will do the work.
greetz
Lucutus
Tried it but with some limited success
can u maybe post an image of the problem…it would make it easier to understand?
If you detach the small tics to separate object and disable the reflection in object properties it will do what you need. The small tics are still reflected only on the side, so they will be not missing in reflection on the rest of the watch.
hmm, nice one, think i will do that, why i didnt think of that, dam
for chrome material better to disable diffuse color
