Hi there,
while navigating through the different tabs of the Visual Settings, some of them disappear until I put the mouse on top.
I’m using Enscape 2.7 in Sketchup 2018.
I would like to see them all the time because I suspect is a malfunction and is not intentional.
That is definitely not intentional, so thanks a lot for your report.
Please uninstall Enscape, then reboot the machine, run the Enscape installer again and in the first window of the installation process, where you will see the checkbox named ‘I accept the terms in the License Agreement’ make sure that is checked. This will enable the Advanced button which you should then click to proceed to the next window which will offer you the option to install for all users of the machine.
If that doesn’t help, we’ll require a feedback report as described here; in the submission form simply add a link to this thread for reference purposes. Thank you so much!
