tried a lot of different render settings but these wires holding the lamps always get nullified by the renderer. What’s the obvious thing I’m missing?
Can’t see image.
how about now?
OK now. What image sampler are you using? Try adaptive QMC over adaptive subdivision as I’ve had similar trouble with lost details.
Yup - probably not subtle enough anti aliasing is loosing the really fine detail - adaptive subdivision is the higher quality one so it should pick up more fine detail - try turning on object outlines too.
I used adaptive subdivision
Changed to adaptive QMC and presto it works as advertised.
thanks
Object outlines?
in general antialiasing has hard times with very thin and straight vertical or horizonal lights. Since there is not enough samples to be taken, the near samples of white in this case wall, dominate the black lines. So usually increasing aa or decreasing the threshold will fix this.
There’s a threshold option with the adaptvie subdivision anti aliaser to take more samples on the outline of objects which might have helped - problem solved either way ![]()
