Disappearing SU Groups
I have noticed that occasionally a random SU group or component will not render in vray…it just disappears. It was driving me crazy until I closed sketchup and reopened the file…then it renders just fine. It’s not a real problem once you’ve figured out to close and reopen, but something to take a look at.
Re: Disappearing SU Groups
Hi Paulj,
I wasn’t aware of that trick…I thought it was group’s hierarchy issue..
I will give a shot next time
Thanks for sharing it
We’re tracking this issue for our service release. If you’d like to send me your scene that would help us test our fixes. Thanks
same thing happen to me.
so, 1. explode group or component
2. regroup again
then you can see the disappeared obj. again in your rendered scene.
good luck.
So far I have been resolved that problem (at least for me) I found that it was a problem with layers: if there is just one object inside group from a hide layer, this group never render. I have a plugging PutOnLayer.rb ( http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/PutOnLayer.rb ) I just changed the layer of gruop (and subentities with this plugin) and it works.
try this.
I forgot something. I have also had fewer problems with the displacement working in the same way: inside the group all objects must have the same material, if one of these objects has a different material (although it has it’s own displacement) displacement is absent. It’s also a good idea that this group should not be within another group.
Do you still need more scenes to test fixes?
