I’ve had one Windows XP computer that for no apparent reason, likes to be disconnected to the network drives (in particular a shared ‘textures’ directory on startup. I’ve pecked around and tried a couple different ‘solutions’ in order to get it working but haven’t been able to figure it out.
There’s nothing like a dark bucket after watching all your passes pass you by…
Then I came across this handy utility today called ‘Network Drive Manager’ which may help some of you that may be experiencing these symptoms:
Hey thanks Mike. I thought Microsoft discontinued Netbios starting with win2k either because of some licensing issue or it introduces security holes. It’s probably not that big of a deal anyways - glad to hear that solution works instead.
If you can setup a windows server as a domain controller with all the wonderfull goodness of windows domains (note saracasm) the issues of disconnect and losing machines by network names goes away.
We are on a workgroup here, and we had this issue with our editing box, when we installed Netbois the problem went away…no guarentees in life or Microsoft unfortunately…
windows domains are far more advanced than workgroups. They allow people to have network logins, so any login can work on multiple machines, network management, all kinds of wonderfull stuff that an MCSE can give you more info on.
Just to add to this post - I still experienced the ocassional ‘disconnected network drive’ even after applying the command line switch. But I think I’ve found a solution
After talking with a friend whos a network admin, he recommended disabling NETBIOS under the advanced parameters and adding the IPs and computer names individually under the hosts file on every computer(c:\windows\system32\drivers\etc\host).
Editing the host files? I completely agree with you. But I much rather have that than having to buy windows 2003 server to keep my few comps under a domain.
if you have someone there that is able to set up a linux server with samba and can spend the time, you might try that
what you need is just a lousy old pentium 3 machine with lots of disk space
samba3 is able to do everything windows server can in terms of file serving
even has some domain server functionality (i havent tried that, normal shares did it for me)
it took me about one or two days to figure out how to set it up (as a more or less complete newbie to linux and samba)
it really rocks compared to windows shares
