If youre using DR with a network drive for textures and you reboot that computer, a mapped drive on the other computers to this will show up as ‘disconnected.’
Does anyone know of a way to have the other computers periodically check and ‘reconnect’ to the mapped texture drive/computer instead of manually having to do it by clicking it each time?
Oooh oooh juju, I hope you get the answer you’re looking for. Ever since I built my new workstation for some reason I have to click on the network drive when I first boot the machine before I try to load a file in max from the Recent Files list.
At first I also had the problem that every 8 hours or so the machine would lose its connection again until a user opened the drive back up. I found a solution on an IT forum that suggested it was a DNS address confusion problem, so I assigned static addresses -- the primary DNS to our file server, and the secondary DNS to our router that feeds us our net connection. Still have to click the drive when I first boot, but at least it doesn’t crap out anymore during overnight renders!
I was really pulling for a decent IT guy for Christmas but Santa stiffed me again, the fat bastard.
There are autodisconnect timeouts (not to be confused with this) which I’ve adressed with a command line solution in another thread.
The only thing I can think of to get around this for now is to throw all the textures onto a computer that I rarely have to reboot - a server server in the traditional sense…
you might consider using a linux machine with a current version of samba for sharing textures and stuff - has no connection limit like windows and comes free (has lower hardware specs as an additional bonus, esp. if you run it in console mode)
takes a little reading to get it right first, but after that it works fine.
btw: i have never experienced any timeouts with windows shares - sounds strange to me.
cu mike
ps: UNC shares worked fine so far - for me they have replaced mapped network drives
they have the advantage that the remote file is automaticly accessible as soon as the share is availlable again
