Discrepancy between GUI and CLI render results
I am experiencing an issue where the rendering results differ between the GUI and the CLI.
I suspect this is because some Render Task parameters are not supported as command-line arguments. For example, “Render Elements” does not seem to be fully reflected:
render_tasks: [render_elements: 16377]}
To ensure that render results match perfectly when sharing scene files and rendering on different machines, I would like to request the following improvements:
  1. Expose all Render Task options:
Please make all Render Task parameters available and configurable via the command line.
  1. Specify Render Tasks via CLI (Ideal behavior):
It would be ideal if we could explicitly specify which Render Task to run via a command-line argument.
  1. Batch processing as default:
If a scene contains multiple Render Tasks and no specific task is designated in the CLI arguments, the system should automatically process all tasks sequentially.
Thank you for your support.
Submitted on AHA Ideas (VANTAGE-I-324).
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
