Displace Problem
hello everyone, I have a problem with the displace in a scene…
I don’t understand why the same map in one scene works correctly while in the other, even setting the displace to very high values has no effect.
thanks
Not
The object where it’s not working most likely doesn’t have proper UVW mapping. You can try applying a UVW Map modifier to it and applying one of the basic modes like planar.
You may also need to enable the “use real world scale” option there (if the texture has it enabled).
thanks for your reply @Maru
You were right, I tried importing the plane where the displace was working, then assigned its material to the plane where I was having problems, then copied the mapping too..and now it works correctly..
There was already a box mapping applied before and it looked fine at first glance…but there was probably something wrong with it
Thanks again
Not
