Displacement and AI Enhancer
Is displacement joining nodes coming soon? Also is there hope for adding Ai enhancers?
Hi @bibin_thomas Thank you for your interest.
While we are unable to share any information about our future implementations nor their ETAs we would be interest to hear your opinion regarding those two features.
Are they going to directly affect your work in a positive way?
What specifics would you add to make them as useful as possible?
@viktor_angelov Node displacement helps reduce engineering size, optimizes efficiency, and Ai enhancers can make work better.​
@viktor_angelov ​At present, vray for c4d needs to update a version with node displacement. Label displacement is really not easy to use.
When you split an object with a geo tag that contains a displacement material, the texture unloads and leaves the field blank. This wouldn’t happen with displacement in the node.
Hi all, thank you for the information. I have shared it all with the Team and will be taken into consideration.
If you have any other ideas, suggestions or expectations, please do share with is without hesitation.
