Displacement and Layered material
Hello guys
I have a base material with displacement and another masked material on the first slot.
I can’t see the displacement working.
Is the displacement working in a layered material?
I am using Beta 1 (05/02/2018) and R18.
Displacement works only in the base layer of the layer material.
Displacement also work by applying 2 textures to object. first displacement and then any other material.
I could make it work, thanks guys.
But I want to mask the displacement. And as I can see it seems impossible with layered material.
Am I right?
yes
Only the displacement from the base material will be used.
To mask the displacement, you need to use the mask in the displacement map itself.
