Displacement and long lenses
does anyone have problems rendering view-dependent displacement with long lenses? For example I have 600mm camera and my render keeps crashing on RAM overload. With short lense there is no such problem even if it covers vider area with much more displaced objects.
Hi, thanks for posting. Are you using V-Ray CPU or V-Ray GPU? What versions of V-Ray and 3ds Max are you using? I tested a simple scene consisting of a sphere with displacement and a camera and a light but couldn’t find a fault.
Could you explain a bit further your workflow? You have a static camera in a scene and you render once with 600mm Focal Length and the other with default (36mm)?
Latest V-Ray 6.1 and Max 22. You can test it on Phoenix ocean, but its not really related to Phoenix. My guess is that its not subvididing only the visible part of the mesh but whole mesh, and because the long lense we can see model close to camera in really big detail the subdivision level will be too hight to fit whole object in RAM. I hope you understand, try to put some big object wih fine displacement in fron of long lense camera.
Even this simple scene can eat my whole RAM (128GB)
But when I change lense to something less its just fine.
Thanks for the clarification, I wasn’t rendering it that close to camera. With such closeup shot the memory shoots up 5 times.
Please check this document - V-Ray for 3ds Max
There it says
View-dependent – Specifies whether Edge length is expressed in pixels or world units. When this option is enabled, the Edge length value determines the maximum length of a subtriangle edge in pixels, and a value of 1.0 means that the longest edge of each subtriangle is about one pixel long when projected on the screen. When this option is disabled, Edge length is the maximum subtriangle edge length in world units.​
So if the Edge lenght is X pixels when the object is far away that may translate in little subdivision since lets say the whole object takes a few pixels of the image. But when we are close and the object takes the whole frame there will be a lot subdivision going on.
But this doesnt make sence. Distance from the camera is not changing and with long lense we see less than with wider lense. If this is true we have to change displacement setting per shot which sound ridiculous for me.
If you create wide lens camera and go closer to the object to cover rougly same sceen space as with long lense the impact on RAM is nothing comared to long lense. And beace it cover same objects part and rougly same screen space there should not be any difference, but it is. There is definitely some issue in displacement computation with long lenses.
I believe, as you asked above, that it does divide the ENTIRE object based on the size of the object in frame (either large object or long lens, or camera close to the object). So if you are seeing just part of the object the parts you are not seeing are still taking up a lot of memory.
Chaos, please correct me if I am wrong, but this is what I have noticed over the years.
One solution is to delete parts of you objects outside the field of view, or slice the object and only apply the displacement to the parts that are in the field of view. Never tried but you might even be able to do this dynamically with a VRayClipper, clipping areas of the displaced object to be (nealry) within the view, and clipping another non-displaced object so that areas in view are removed. But I am not sure if Clipper clips before or after displacement. If after then no bueno.
Yes the displacement is calculated for the whole object. If you are using VRayDisplacementMod you can animate the Edge length to increase when the camera is very close to the object and try to reduce the memory consumption this way.
Hmm I would call this a bug, because its not view-dependent then. And how you explain that it works with wide lense camera as i explain in post above?
“If you create wide lens camera and go closer to the object to cover rougly same sceen space as with long lense the impact on RAM is nothing compared to long lense. And beace it cover same objects part and rougly same screen space there should not be any difference, but it is. There is definitely some issue in displacement computation with long lenses.”
1 image is better than 1000 words. Wide camera closer to the object take us few gigs. Long camera take up whole RAM or crashes. Screen coverage is the same, so this is definitely bug. Should I post it as oficial bug report or you can do it?
EDIT: Max file in attachment​​
disp_bug.zip (74.5 KB)
Hi @frodopytlicek and thank you for bringing this up. It turns out it is a bug.
I did a test scene according to your explanation and indeed with a long lens camera the memory consumption is significantly higher if we have the same area of our object in the frame.
The issue is reported under VMAX-13104 in our bug tracking system.
Great glad to help. Can this be somehow prioritise? We have project where a lot of long lenses are used and we cannot render because there isnt a workaround. I have access to nighties so let me know when it’s available. Thanks
That is indeed really weird.
Did you try disabling Tight Bounds and Cache Normals (cache normals is off by default). I find these two options can slow things down tremendously in some scenes.
Interesting.
Looking forward to the results of this research. Currently I am having serious trouble with displacement in 3D mode running out of RAM. The lens is fairly long too, so possibly related to this issue here.
Hi, still no solution for this problem?
HI, the issue has some progress but it is still not available in nightly builds. We will notify when we have something ready for public use.
Its realy big issue someone else must encouter it. I’ll be glad for any possible workaround.
Is this already fixed? Its driving me crazy :frowning:
Hi as of now the issue is not fixed. Excuse us for the inconvenience.
