(sorry for the large image, but the text was pretty hard to read when scaled down).
-On the left you can se my displacement-bitmap settings.
- In the center you see the framebuffer - and the problem.
- Below the framebuffer you see the bitmap-image used to drive the displacement
- On the right you see the settings of the Vray Displacements modifier.
The problem is, I cannot in any way seem to get rid of the border that the bitmap creates. I have tried all the combinations of settings in the modifier and the bitmap windows that I could think of, but to no avail.
Anybody has any suggestions? - would be very much appreciated, as I am soon about to begin work on my final project for school, and need this feature pretty bad.
Your going about it the wrong way.
You telling the displacement to displace the white parts of your image which is why its messing up.
Invert your iamge in photoshop so that the text is white and the rest is black. and when you displace it, it will stick out, so just use a negative displacement amount and leave the shift on zero.
