So I was creating some materials and changed the black point setting and got the follow error message. (see image)
Cinema R16 with Alpha 6 RC6
I’m guessing this isn’t normal…
Ben
Is it possible you are working in kilometers / miles in your scene and you have a 5000x5000 km / mile (insanely big) object?
No, I’m in cm’s and using the shader ball from corona-materials.de which is set to 20cm grid spacing. I’ve had this problem in the past.
Hi Ben, does this happen in some specific scene? If so, can we have it? Otherwise, we’ll close this
This issue hasn’t popped up again so I’m guessing it’s safe to close it. ![]()
