Displacement Capping
I’m having a little problem with displacement at the moment and hope someone here can help.
I am creating a timber slat wall, with the slats every 1200mm. The slats consists of a bottom panel and then a top layer, the top layer having a gap of 50mm showing the timber from the bottom layer. Rather than model this out for each wall I decided to create a displacement map.
However, when I render the image there is a hole to the underside, which ideally should be capped. Anyone know how to solve this problem.
FYI, displacement is 2d Mapping with an amount of 20.
Regards
Thox
You could try a very thin black line at the bottom of your displacement map.
