Displacement continuity with 2D Displacement
I’m rendering a beveled edge with a file displacement map. I added the subd, subd quality and disp. control attributes to the shape.
When I use the 2D Displacement mode i get black edges at the poly edges. The ‘Kepp Continuity’ checkbox is grayed out. However, when I switch to Normal Displacement, turn on ‘Keep Continuity’ and switch back to 2D Displacement the edges are fine. So why is the checkbox not available in 2D Displacement mode, as it obviously has some influence on the rsult in both modes?
Thanks!
V-Ray for Maya version 2.15.01, revision 17621 from Nov 19 2011, 07:44:53, Maya2012x64SAP
We reproducer the issue and forward it to the developers.
Thank you for your feedback.
