Displacement edge tearing
My first post on the forum,
First off all, hi everybody and congrats to the developer for a wonderful rendering engine!
I am trying to improve my final exam renders and decided to use corona.
These are the original renders I made, modeled in autocad with my partner Rizzo Nicola and rendered using Vray.
The time was tight so I wasn’t able to do everything I wanted, but now that my leg is broken I have all the time in the world :smiley:
I started setting up the scene in corona, illuminating was a breeze, only need to sort the dark part on the entrance, maybe using a plane with CoronaPortalMtl?
I’m having some problems with the brick displacement.If I apply the displacement directly to the object, i get open edges (sorry for the not finished render)
I tried a trick that user maru posted and applied a smooth modifier to the mesh with threshold value of 180 and I get this :frowning:
displacement settings are projected size 0,4 and max subdivision per poly 200, I tried with lower/higher values but I get WTF error bad allocation…
Thanks in advance and sorry for the long post
