Displacement edges
Anyway to fix displacement edges which are broken…?
Thanks.
This looks more like UV unwrapping issue rather than displacement problem. Unplug the texture from displacement and plug it into diffuse - likely the issue will still be visible.
that UV I did not fixed… I thought may be fix in other way…!
Thanks.
Not sure if i understood you correctly, but if UVs are bad, then there’s no other way to fix the issue - you need to fix UVs first.
Thanks. You were right, it was Uv issue.
I thought may be any other quick way to fix without UV… but UV done and fixed.
Thanks.
