Displacement From Mari
Hello, I generated a displacement map in Mari from a hires mesh ->lowres. The shader in Mari shows the displacement perfectly, but I’m struggling to get a similar effect using the VrayDisplacementmod. I’ve linked my scene with the displacement maps. Any help would be wonderful.
https://www.dropbox.com/scl/fi/z4855lpdvtn1gf5smv8u2/Mari\_Displacement.zip?rlkey=010a6p2qlqer74lnknycgf022&dl=0
Khye Kading
You are using a normal map as displacement, which is why it doesn’t work, so you’ll need to export a b/w displacement map from Mari :slight_smile:
