Displacement (geometry tag) on multiple objects
I have 1 object with a displacement texture in a geometry tag. This renders fine (see photo 1)
If I add a second object with a different displacement texture in the geometry tag, the rendered first object gets the displacement map from object 2. (as in photo 2)
Is there a way to get different displacements on different objects? Now I can use only one.
I use Vray 5 and Cinema 4D R23 on a Windows 10 PC.
Now, I know why it looked sometimes so strange… when playing around
So, same here… worked only, when I switched on the subdivision on only one Tag
Simple file attached…
Displacement.zip (1.03 MB)
hope it will be fixed soon, as displacement is very elementary… thanks to your post I can see whats wrong on another scene I am working on
Hi, this is a bug on our side, that may happen if two objects have exactly the same underlying geometry (which happens when you clone an object). I have logged it for fixing and it may soon be fixed in stable nightly builds.
This issue has been fixed and it is available in the latest stable nightly builds. You can download and install it from here:
