Hi
Adding a displacement map in one of the multimats assigns displacement to all materials in the multimat.
Regards Nikolaj
Hi
Regards Nikolaj
Are you using the Max Multi/Sub material in this setup ?
I believe this is a known issue which we have to fix and it happens with RT CPU engine as well.
Yes it’s the max Multi/sub…it’s been logged then, I guess the workaround right now is detaching the part that need displacement and assigning a seperate vray material.
