Is it possible to apply a displacement map to a material rather than an object?
Hi @andrew_maclaggan ,
It is till possible by adding a Displacement attribute to your material (see screenshot), however, this is a legacy attribute and will be removed in the future - we’d advise you to use the geometry displacement modifier instead. To read more about it, please visit V-Ray for Rhino
Thanks @nikoleta.garkova . I will do that.
I am curious why it needs to be removed, it seems like a good thing to have multiple paths to achieve a result. In this case I need to apply the displacement to a material because I have no control over the individual element which is a part of a larger element. The larger element (a piece of topography) is generated by a plugin which allows me to divide the surface into different regions by material but that’s all the control I have over each individual piece. In this case, I would like the roads to be displaced up or down, and a displacement map seems ideal for that.
