Which is to prefer in terms of memory usage and render times? What is the difference between the two?
Not sure, but I like the fact that you can blend several 3d disp maps with the map using vertex colour or other masks. I haven’t found a way to do this with the modifier (though I’m sure it’s just me)
I’m using 2d displacement only (for grass, bricks, etc), so it only works with the modifier.
