when I use Vray demo version to rendered the Bump map & Displacement map in the same scene. The image I got is not as what manual described. The two rectangular blocks look almost the same. Actually the left one set as Displacement map with multiplier value as 2. The right one set as Bump map with multiplier value as 2 as well. Please advise…
by the way, how can i insert image here? the button above doesn’t really work
thanks
