displacement mapping bug?
Hi all
I tried to make a gravel floor with arroway tex (They deliver displacement tex and diffuse, which I put in the respective channels in the corona material)
When I render, It seems the displacement is not matching the mapping of the diffuse tex (and vice versa)
see examples here. ignore displ roughness please.
diffuse only
diff+displace
Am I overlooking something?
Its the right combination of diff/displ, I tried in Vray and it works there.
thanks a lot
keep up the great work!
bboo
SOLVED:
the displacement tex needs to be flipped horizontally, even if it is the correct orientation when you look at the tex file in mat preview, windows explorer etc. Works now.
bboo
