the displacement Node Material seems to be missing in the latest nightly build from last night. A message appears when opening and saving a scene with this node.
Hey @haniel1107 , can you please double check the exact version of the build you have downloaded and installed.
To elaborate a bit more - technically the latest build is 33702 from Aug 1, but it is a build of version 7.10.02, where the displacement material is not yet available. This was caused by the back-porting of a fix (from this issue).
The latest build of the newest version, is build 33700 from 31 Jul (version 7.40.00), and it contains the node material.
Hello @deyan.hadzhiev , yes you are right, it was the one from the 1.Aug 33702.
Here I had the error message regarding displacement node.
The one from31 July is working fine. Thank you…
